RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
The motor is a Turnigy Typhoon 3450Kv, 12T pinion. Higher headspeed the other 450s.
The tail is setup mechaniallly in rate mode.
Another issue is that I still cannot get the blades to track correctly, even after replacing the main shaft...
