ORIGINAL: Kozzy_98
The motor is a Turnigy Typhoon 3450Kv, 12T pinion. Higher headspeed the other 450s.
The tail is setup mechaniallly in rate mode.
Another issue is that I still cannot get the blades to track correctly, even after replacing the main shaft...
If your running 100% throttle curve with a 12t it should be more than enought headspeed. Do you have a different set of blades you can try ? Also have you weighed the blades and balanced them ?
Did you end up getting the set of adjustable linkages with the reverse thread on one end of the rod. You can get the tracking perfect then.
