ORIGINAL: Joshsubmec
Also how long might I be able to run with a total of 10,000 mah in there at about 3/4 throttle constant. Is there some sorta calculator or math I could do to figure this or is it something you time yourself when your out on the lake?
first the lipos you listed are only 2650mah... you need 5000mah +
and runtime on 10,000mah.. you need amp draw and we could figure this out
but lets say your pulling a constant 55amps then your runtime would be about 9min
http://www.offshoreelectrics.com/conversion.htm
and I buy most everything from OSE
