ORIGINAL: BillJ
2. Missed the first approach, upon applying full power and pulling flaps, plane took a downward bobble when power hit.. Probably will just apply power and climb out dirty.. I'm sure a throttle mix with elevator will fix issue.
Bill
That is the down thrust in the plane.. if you could tilt the front of the motor down maybe a washer or two it. My skymaster did it everytime when I hit full power, almost a instant nose dive.
