ORIGINAL: Captmicom
I got to tell you Al,
They are using the same carb on this new 26cc beam that is on the RCGF 32cc so that tells me it might be making some serious HP. I am swinging 22x10 and 22x8 props on my RCGF 32cc at 6800 to 7200 on the ground. I will keep you posted when I get it run tested. I am looking at maybe putting it a 86'' span Giant Scale Sopwith Camel swinging a 20'' to 22'' prop if I can.
My thinking was in the other direction. Taking advantage of that power to weight ratio? That engine on a 3D (or sport?) plane that was performing well with a 20cc anything on it should...... well, put a grin on a lot of faces? -Al
