RCU Forums - View Single Post - Dynam Peaks Pitts servo will not center and ESC issues
Old 04-28-2013 | 02:18 AM
pcnewman
Default Dynam Peaks Pitts servo will not center and ESC issues
I just sent the followng letter to Nitroplanes. Have ay of you had the same problems?:
I received my order in great shape and on time.
I do have a problem with the rudder servo though.
It will not center itself.
When I attempt to trim it, I can put 3 clicks in and the servo doesn't move, then one more click and it moves enough for all 4 clicks.
Other times I can give it one click and it moves 3 or 4 clicks worth.
Sometimes when I'm moving the stick back and forth it will return to center, othe times it won't.
I have changed the receiver, then the transmitter, then both, with the same result.
I'm not trying to beat you guys out of a servo, I'll gladly pay for it, if that will fix the problem.
I'm using a Spektrum Dx6i.
Also each time it power up the ESC it goes into a series of short quick beeps, like the throttle is up. It's not and the trim is centered. If I disconnect and reconnect the battery, it seems to work fine.
Any help you can offer would be greatly appreciatted,
