RE: Dynam Peaks Pitts servo will not center and ESC issues
Will do on the servos. I did work the servo back and forth (with the Tx) for about 10 minutes trying to clean up the servo motor. Made a big difference. I think I will still swap them out though.
I'm just connecting the battery just like you would for flight. No switch. Replaced stock plugs with Deans. The last 2 times I powered it up it did fine. Strange.
