RE: Cut and Paste
Hi Ed,
Sometimes you can use the control-C and control-V on your keyboard, where they don't give you a menu option.
Hold the control key and hit C after you've highlighted what you want to copy, then go to where you want it pasted, hold the control key and hit V, and it should work.
This can be called the Copy and Vaste method (if you hit control P for paste, you usually get a Printout).
Drew
