RCU Forums - View Single Post - Dynam Peaks Pitts servo will not center and ESC issues
Old 04-29-2013 | 04:15 PM
pcnewman
Default RE: Dynam Peaks Pitts servo will not center and ESC issues
OPJOSE
Thanks for the reply. Lots of good info.
1-No binding. I had already broken hinges in. But tried with pus rods disconnected.
Gears seem to be fine. It will center now and then. I worked the servo back and forth (with the tx) for about ten minutes to try to clean the servo motor up. It did seem to help but still not right.
2- If you notice at the top of the post I stated that I had sent the following letter to Nitroplanes. So it was Nitro planes I was speaking to, not anyone here. The reason I posted it here was to see if anyone has had the same problems.
3- I should have said that the ESC sometimes beep short beeps continously not a series. I'll try what you said about teaching the ESC.
