Kyosho Pitts ARF
First the model does not come has show on the pictures. At least mine did'nt come with the wires as shown. Additionally I have had nothing but problems with my PITTS. For some reason my model has uncontrolable yaw to the left. This is present on the ground roll, right rudder will not hold against the left torque, and in the air, aircraft makes flat (REPEAT FLAT) left turns.
I have had several advanced modelers look at the Pitts to determine the problem, I thought it might be my construction of the ARF. However, no problem was found.
I have been in contact with Kyosho regarding this problem. At first they recomended increasing the engine offset, they thought it might be the torque of my OS 46FX. This made takeoff easier, normal right rudder input, but the aircraft still made flat left turns, especally at high rpm.
At Kyosho's request I have cut up my ARF and sent it back to there review.
Anyone else have the same problems? I would like to know.
