RCU Forums - View Single Post - Saito 91 problems
Old 09-20-2003 | 11:27 AM
yard-dart's Avatar
yard-dart
My Feedback: (35)
Default Saito 91 problems
I've got a buddy that has the Saito 91. The engine is pretty much still breaking in, it may have 3/4 of a gallon through it. The engine has run great right out of the box until about a week ago, it got to where it just would not run on the low end. Now I'm no rocket scientist, but I do no how to tune an engine. The valves have been adjusted. The engine is mounted on it's side, which should be no problem because I've got two 91's and a 100 mounted on their sides. The kicker of it all is that the engine runs flawlessly with the heat on the plug, but as soon as you take the glow starter off, the engine goes dead. As long as you have it at 1/4 throttle the engine runs fine, but pull it down below that and it goes dead. I've adjusted the low end like there is no tomorrow, but is is really hard to think you've done any good if the engine will not idle at all. Like I said, with the heat on, it actually runs better than mine. It will idle down to around 1800 RPM an run there all day long. The transition is superb and we tached it at around 9K. It will run like that on high end without the heat, just not on the low end. I personally put in an OS F plug, no help. He is running 15% nitro/20% oil which is ample nitro to achieve a smoothe idle. I told him that he may have to get an on-board glow to keep it running, but he didn't like the sound of that and said that he would just sell it if it came to that. It is his first four stroke, that I actually encouraged him to buy, but after the trouble this engine is putting him through, I doubt he ever buys another. It's got me stumped. Should he posssibly have to install an on-board glow to keep it running, and if so why? If it shouldn't be needed, what do we do to fix the problem.
Any advice would be greatly appreciated,
John
