RCU Forums - View Single Post - 25% Cessna L-19/0-1 Bird Dog build
Thread
04-30-2013, 10:55 PM
937
rigrandy1959
RE: 25% Cessna L-19/0-1 Bird Dog build
Thanks Gaines.. hope your builds are going good.. Vailly has 4 12 X 18 sheets for 21.00 . I looked on Widget Works and can get 12 X 18 .020 petg 8 pack for 23.00..think I will go that route..also a question as I think you as the scale master builder. I have a small homemade vac former 18" X 18". the side windows " see below picture" I was thinking of making a mold of the side windows with a small lip the thickness of the fuse and install them from the inside. the other way is I made some frames and was going to glue flat sheet to the back of the frames and install from the outside, what do you think, ? ....also on the tailwheel I made, the control horn is cheap plastic and has slop, any idea on making a metal one ??.. I have the cockpit kit but was going to wait intill a couple of flights before I spend the time to detail out to cabin.
Reply
Like
rigrandy1959
View Public Profile
Send a private message to rigrandy1959
Find More Posts by rigrandy1959
View iTrader Profile
