RE: Jet /Flap set up on Futaba 14sg
If you put the Airbrake function on a three position switch it will give you three position flap on the ATV function, or alternatively put the function onto a side slider and have infinitely variable positions, you can even have the function connected to throttle to put the flap and reflex away to a half positon flap automatically if you open up to go around.
Mike
