Futaba Snap roll switch programming
Hi all,
I am setting up a new model on my 9C and am having difficulties programming the snap-roll switch.
The mix cannot be turned on. When I try to activate it I only have OFF and INH values to choose from. The saftey feature is turned on, but the availability of the mix does not change if I change the gear switch. I cannot see any of the programmed mixes that are already using the switches that the snap-roll function is supposed to set up on either.
Any ideas? Thanks for your time.
