ORIGINAL: clarkmodel
Hi philipat,
1) PzIII sound version is only availiabel on TK22 platform,
2) "rotate the turret, raise/lower the bbl and fire the machine gun at the same time while driving" this can not be done becasue TK22 is 4-CH operating board.
3) Only TK22 has gun barrel elevation servo port, you just need to plug a servo to it.
4) Only TK22 has "momentum" feature.
5) both TK20 & TK22 support airsoft with sound trigger.
TK22/20 are 4-CH operating board, no separate switch for something like starting the engine or firing the machine gun.
Regards,
Clark
Thanks for the response. The TK20E can control the HL elevation in both directions, correct? And, does the board come with the 4-pin plugs that you show on your webpage for making that work? Or, would Ineed to purchase those separately?
Also, any plans to add channels to the TK22? Maybe make it a six channel?
Philip
