RCU Forums - View Single Post - Uproar maiden
Old 05-02-2013 | 06:57 AM
flybyjohn
Default RE: Uproar maiden
Yep, you did. If I remember right you did say they would create a lot of lift at higher speeds. This plane is not that fast, and the tendencies happen at lower speeds also. These floats are just like normal floats with the rear cut off. I wonder why they make such a difference in the behavior of the model. I will take it up again on Sat. and Sun. and see if a slightly different angle of the floats make any difference.
