RCU Forums - View Single Post - using rudder
Thread: using rudder
Old 05-03-2013 | 09:20 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: using rudder
It is really best to use rudder manually before using a mix. There is nothing wrong with using mixes to make airplanes fly a little 'better', but that is personal preference, and you should understand how much rudder YOU want mixed in, and when you want it.
Using a mix is not 'free' - it might help with turns, but it will affect the airplane in other ways that you may not want. A roll, for example. You input aileron to roll the plane, but your mix is adding in rudder, so you get a barrel roll instead. Or when landing, you might want some wind corrections with aileron and elevator w/o rudder.
