ORIGINAL: Hossfly
ORIGINAL: Bozarth
This is simply not allowed. Please do not ask about it again. 10 to 15% percent would be a good starting point but I do not believe this would be legal at most flying fields. You should probably contact AMA directly, or SFA if need be.
Kurt
Pardon my thoughts, however your above statement, if really aimed at "rye", then you, IMO, are an "airplane-driver", and not a PILOT !!! You must really be acting in jest!.
Good one..LOL
I've been around enough to have read many of Bozarth's post, and yes, I believe he is jesting, in part. His harmlessly sarcastic and implied point is the same others have mentioned and is a valid one IMHO: ....... Add rudder manually if you want to learn how to use the rudder, using a mix will not teach you anything and really won't be desirable on the Tiger in the picture or the Edge standing up in the background.
<br type="_moz" />
