RE: Picco P-zero 0.8cc
Well, it sounds to me that I'll have to try and prove the skeptics wrong. Skepticism is healthy, justified and necessary. And it is very true that while I can control what I do to deliver the goods, assuring that the production unit will do so as well is the real trick.
In any case, I've got the numbers to shoot for, we'll see what happens otherwise.
CP,
The Picco/Brodak hybrid uses a head button, clamped down with a finned, cylinder head. You say that circlips in the piston rust and break. How does Cyclon retain the piston pin?
