RCU Forums - View Single Post - using rudder
Thread: using rudder
Old 05-04-2013 | 04:46 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: using rudder
ORIGINAL: ARUP
Use the rudder manually. With experience you'll make a decision as to what you want to do. Personally, I don't mix anything. I think it's more fun to actually have to make the flight control inputs myself! Nothing more fun than crabbing a Cub down the runway rolling one wheel, lifting, crabbing the other way and then rolling the other wheel. Can't do that if you mix stuff!
Why not?? The rudder still works when you mix in a little offset. you guys make it sound like if you have a mix the rudder it will no longer respond to the rudder stick movement,, all it does is adjust the trim position slightly.. The rudder still works.
