RCU Forums - View Single Post - Installing Engine
Old 09-20-2003 | 05:31 PM
Digimortal
Default Installing Engine
I just finished installing my VZ-B(p) engine in my mbx-5. Man is it beautiful. Anyway, I first installed the shim, then the cone shaped piece on the crankshaft, but when they first say to install the shim, when everything else was installed the clutch bell would not turn. So I left the first shim off. Is that shim supposed to be there? It's the very first shim that goes on the shaft, the one right up against the bearing on the engine. Thanks in advance. I hope this made sense.lol
