RE: Picco P-zero 0.8cc
Probably a mk 1? Just ground off the crankpin *** off and made a spinner for the Picco. Looks like a wierd setup on the crank. Both bearings are the same ID. I have more than .010" endplay, have to turn a bit off the step of the crank? Then finish the backplate and make a venturi and needle valve.
