RE: Picco P-zero 0.8cc
crank material, Picco used 8620 carbonized. I used A2 heat treated to 60 rc. I Can do cranks for $70. One that fits a stock case will do you no good, Too small just like stock. The cost goes up with boring the case dead nuts on center and replacing the rear brg to fit a larger crank and what timming do you want.. what do you want in a de stroked larger crank?? the project is a lot more work than people realize. add on the cost of the prop mounting plate, stud and spinner or nut...
