RCU Forums - View Single Post - Aileron Differential on Trainer
Old 05-05-2013 | 07:22 PM
Charlie P.'s Avatar
Charlie P.
Default RE: Aileron Differential on Trainer
If you trulywant differential with a single servo you will have to use the round "arm" and drill holes offset from 90° by 30° (120° apart). Or, youcan use the 4-way arms and offset the contol horns so the holes are not over the hinge line (not recommended). You coud use the 6-arm head, but using twoarms 120° apart .
For best results you want more up throwthan down, by the way.
