RE: GP extra 300s build
i'm not sure exactly what your trying to describe.did you glued the vertical straight up and down but twisted it somehow when settting it in the fuse and your looking at it from the front of the planeand see it off centerwhere it meets the fuse? ifso i would think adjusting the rudders trim when flying to counter act theoffsetverticalfin might only be a few clicks. another option less desireable would be to use a blade and cut the sides loose to reglue.....messy and maybe unnessasary.
take a picture fromatop veiw ,set up perfectly over the vertical/rudder and fuse so we may see the problem that way. if we can ,you may want to go ahead with the repair.
it's not in any planes design i ever built that the vertical is angled left. i hope you can leave it as is and enjoy flying her as is,she's looking great!!
