RCU Forums - View Single Post - How do I do this?
Old 05-06-2013 | 09:45 PM
Springbok Flyer's Avatar
Springbok Flyer
Default RE: How do I do this?
Bax,
This is not working for me, here is part of the reference that you've quoted: I have made comment in ((brackets)) where I have a problem.
You will want to exit the Condition screen now, (leaving your switch set to the Up position as that you remain in Condition 2 and go back to the Function screen in your Linkage menu. This time you will again go to the channel 8 Fuel-Mix (or whichever function you have your pump on) and make sure that both Control and Trim are NULL. (( When I come back to the Function here, the control and trim is still as I had set them in the first place with the first condition - if I now change both to NULL, it also changes both to NULL in the first condition)).
Basically what I want to do is the following - please give me specific instruction on how to accomplish this:
- I want to use switch SA (which is a 2 position switch on my Tx) to switch the smoke pump on or off (regardless of my throttle stick position - see below).
- I also want to use my throttle stick (mode 1 J2) to start the smoke pump (if switched on with SA) at 30% throw and continue it working all the way up to 100% throw. When I bring the throttle back to idle (or below 30% throw) I want the pump to stop.
Thank you for your assistance.
Jan
