RCU Forums - View Single Post - An Exercise in Install Practice....
Old 05-06-2013 | 09:55 PM
  #70
stevekott's Avatar
stevekott
Default RE: An Exercise in Install Practice....
ORIGINAL: CraigG
ORIGINAL: lov2flyrc
There has been argument that Festo fittings will leak under suction never to use them on the suction side. NONSENSE! The Festo quick star fittings are rated for about -20psi. I have never had one leak. Square cuts of the tubing is key for good seal in the QS fittings.
Todd
Attached is the Festo spec sheet for the 6mm Festo Ball valve. The valve is rated at 10 bar (145 psia) of positive pressure and 1 bar (14.5 psia) of vacuum pressure. So, when the valve is placed on the suction side of a fuel pump then its only good to 1 bar of suction pressure. Having seen how a P180 or P200 sucks in the sides of a BVM UAT, I would think that it is pulling more than a 1 bar vacuum.
We lost a jet at Miss Afterburner this weekend due to a flameout. We found the CAT empty and all fuel lines/connections full of fuel and secure, EXCEPT, the fill line which was dry. The guy had installed a 6mm Festo valve in the fill line. We concluded the P-200 had sucked air through the Festo fitting. I can't say for sure that the fill line was securely pushed into the fitting but it was cut squarely.
I've used Festo's on the suction side myself without problems but after this incident, I'm not so sure.
Craig
14.5 psia is about one atmosphere. At sea level that's about the maxim pressure you can generate pulling a vacuum, no matter how hard you suck, no matter how powerful the pump. It's about 33 feet of water column. That being said it is easily enough pressure to crush just about any thin wall fuell cell.
I think you could safely get away with putting that little ball valve anywhere you would like after the UAT. I DO think a poorly cut tube in a festo fitting is more likely to leak under vacuum than under pressure. And most certainly if someone mistakenly uses Tygon tubing in a Festo fitting. Notably if the fitting leaks under pressure you will have liquid fuel leaking out. Under vacuum, a silent killer
Happy Flying,
Steve
<br type="_moz" />
