RCU Forums - View Single Post - An Exercise in Install Practice....
Old 05-07-2013 | 11:51 AM
  #83
marc s's Avatar
marc s
Default RE: An Exercise in Install Practice....
Matt, no adhesive, the UAT was held by a clear piece of heatshrink you can just see around it, under this is also sandwiched a piece of thin glass board (you can just see the yellow at the base) which was slightly larger than the UAT top and bottom, this was screwed to the lite ply plate underneath.
Now naturally I use the CAT which has its own simple mounting
marcs
