RCU Forums - View Single Post - battery size??
Old 05-08-2013 | 06:09 AM
SAB
Default RE: battery size??
Tony,
Was mentioned above but it's important to know what type of power plant you are using - the 50mA per flight numbers mentioned above only relates to electric power. IC power is usualy significantly more, up to 250mA per flight (because the servo's working much harder fighting the engine vibration, even if soft mounted).
Steve
