RE: How do you tune a 3W-100
How many turns open for the low end needle? If it's too rich, it will effect the mixture at full throttle and you will be trying to compensate by leaning the high speed needle. I'd call up CA and ask if they actually ran the motor. If so, it may be something you are doing that they didn't do that is causing the problem. Good luck
