RE: CMP Zero Makeover
Thank you Prekin,
It is the 82" version. I wanted to keep this one simple, (but I also love alittle detail) so I wanted to test out a method to give it some "pop" without it being a total rework. I tested with Testors aluminum and silver enamel paint, on some old composite flaps until I had an idea of how I wanted to do it. I found that the aluminum looked good when applied, but "grayed out" a lot and became quite dull when dry. The silver on the other hand, worked quite well. It is applied with several different little pieces of sponge, to give different textures. I only have half of the fuse done so far.
Casey
