RE: HL-Tiger I: How to open and remove the Tiger tracks
Easy Track removal without removing a Track pin
1. Use a sharp tool to gently remove the front drive sprocket centre cap.
2. Use screw driver or Allen Key tool to unscrew sprocket fixing screw from drive shaft.
3. Gently force the sprocket out from the drive shaft – there is enough clearance to extract the drive sprocket while the tracks are left as is in a continuous loop
4. Tension the front road wheel allows removal
5. Reverse procedure to reinstate
This technique takes the hassle out of aligning the track pin while under tension
