RCU Forums - View Single Post - Correcting incidence
Old 05-08-2013 | 03:47 PM
BillS
Default RE: Correcting incidence
ORIGINAL: karolh
Having a bit of positive incidence on the wing can be a good thing, however you have not mentioned just how much down (negative incidence) if any does the horiz. stab. have, and as is how does the model fly ??
Negative on the stab will also be 3/4 to 1 degree relative to a neutral wing. A quick CAD sketch verified the numbers for the stab.
The model has 115 flights on it. The model flies fine but much trimming for flight is how the prop came to have 4 degrees down. None of my Kougars fly well upside down.
Thought it might be time to see if a real incidence fix could be made.
Bill
