RCU Forums - View Single Post - An Exercise in Install Practice....
Old 05-08-2013 | 06:05 PM
  #91
TUMBLER
My Feedback: (13)
Default RE: An Exercise in Install Practice....
Thanks Todd. Ok this is what I get when I do what you said. This tell you anything? I am going to go get my manual.
Brian
ORIGINAL: lov2flyrc
Nicely Done DrV!
TUMBLER
After each cycle of operation, the FADEC stores the last cause of shut down and the values of RPM, temperature and pump power at the moment of shutdown. In order to access these measures,
Set the trim down (TrimLow) and push the left button on the Data display. The FADEC will display the cause of shutdown and the measured values at the moment of shut down. This will provide the last off condition, if you have attempted another start since the flame-out, the needed data is gone from display be stored in the ECU.
During engine operation the FADEC measures and stores all the engine operating parameters recorded during the last the 51 minutes of operation in .5 sec intervals. These measures can be downloaded to a PC to study the behavior of the engine in flight or to email the file for us to diagnose any possible problems. You would need the FADEC USB cable to download the data.....
Todd
