RCU Forums - View Single Post - Correcting incidence
Old 05-09-2013 | 02:59 AM
sensei's Avatar
sensei
Default RE: Correcting incidence
Insure that you are using the correct longitudinal fuselage center line, reset your thrust line to 0 and spend a little time sanding and reshaping your wing saddle utilizing your LFCL as a reference until you achieve your goal, whatever that may be. You can trace your saddle from the fuse side and use it as a quick reference guide as well.
Bob
