Yup water is a lubricant too...
Going by the circular logic used before, oil would not be a lubricant because it displaces water!
Anyway back to the OP...
I'll bet his throttle barrel is frozen and needs to be loosened up.
It would be best for him to loosen it, WD-40 works great... then remove the carb and clean it out as it may also have gunk in the needles and nipples.
