RE: New to Nitro Throttle cable/pushrod
how about wd-40 contains lubricant.... :-P
As for the original post. if the throttle barrel isn't seized, often times the pushrod just needs to be supported in some form or another to prevent flex. fashioning some sort of bracket/brace out of spare balsa is pretty common and helps to remove the flex in the shaft.
