RCU Forums - View Single Post - servo problems
Old 05-11-2013 | 01:00 AM
phmaximus's Avatar
phmaximus
Default RE: servo problems
I second the use of lock tight it works a treat.
If it has come loose a few times I would recomend inspecting the servo horn, the chances are its now slightly striped.
There are plenty of different strength thread locks out there a bit on common sence goes a long way.
Like SyCo said red is overkill for a servo, I recomend blue, but if u feel that's to strong pink is a lot safer.
My suggestion is to check out the fact sheet and recomended uses for each thread lock. Most servo Manifactures recomend using thread lock.
Note: lock tight is only good for metal geared servos
