ORIGINAL: kirtsm
Hi Jimmymac, sorry it took me a while to reply. What I did was to drill out the e-flites in my drill press. It has been over a year ago, but I think I used a 7/32 drill bit. I think it could be done with a hand drill because you are just following the existing hole. I used 7/32 wire so I had to drill out the struts to 7/32 also. Again this is only about .025'' bigger than the exilting hole, so it is fairly easy to do with hand tools and standard drill bits. Hope this helps.
Good Luck, Kirt
Thanks Kirt.
