shalom to all
here some more pics of the intensive work on this model which is not AN ARF!!!!
lot of sbading and modifications is needed.
3 rear servos were instaled lateley togather with the hatch locker for the canopy, the rear side of the canopy will be tighten with lock nuts on the canopy and 3/32 bolts.
i didi a mistake with the servo positions place - as i did it identecaly paralel to each other -> ELEV to ELEV-> a noraml servo wont fit in as they will touch each other...
so i will use HITECH BB77 which is 5.5Kg@6V per each ELEV surface, should be effcient
enjoy the pics and thank you for watching
comments are welcom
