RCU Forums - View Single Post - Servo question
Old 05-13-2013 | 05:05 PM
mattnew
Default RE: Servo question
You'll need to determine if the "common paths" between the 12 servos and the battery can supply the amount of current the 12 servos can potentially/ or rather likely draw. <div>
</div><div>So....</div><div>
</div><div>Battery -&gt; Switch-&gt; Voltage Regulator -&gt; Receiver -&gt;Servos </div><div>
</div><div>Thats obviously if you aren't using anything like a smartfly.</div><div>
</div><div>With that setup, The battery receiver and servos will be ok... so your main question to solve is can the switch you choose and the voltage regulator handle the amps that the servos will draw... if they can't they'll melt first. </div><div> </div><div>I'll +1 looking into a redundant setup for this large bird.</div><div>
</div>
