making sure all your parts fit together like they should
metal expands when it gets hot. If you break it in cold then when it gets hot it will be loose( like no compression)
Do an experiment.
turn over a new cold engine.put it in the freezer first:-)
then heat it with a hair dryer and see what happens.
A engine must be broke in at the temp it is designed to run at!! right??
