RE: Rossi R45 RE - Info & Manual?
Jim,
Thanks for the info. Very helpful.
CP is an all synthetic fuel if I'm not mistaken. It's interesting that both Webra and Rossi are running well without castor. Have you tried running Omega on them? 22% oil does sound rich. 18-20% might be interesting to try.
Would you be able to snap some pics of you R45? I'd be interested in seeing it.
I'll take some too and check the carb. I believe it is an 8.5 though. As the exhaust, the crankcase carb inlet is also the same bore as the 60's so the 10 mm carbs could potentially be used as well. A pump on the 10 might also be interesting to try.
David
