RE: evolution 10gx issues
You mean Tygon line ...right?
Did you pressure check the tank for leaks especially around the stopper?
Did you seal up all the sections and the bolt on the muffler so it doesn't come loose and/or leak?
How is the low speed for transition from idle to mid-range and idle to full throttle ....what does it do?
How is the high speed for full throttle/top end?
