RCU Forums - View Single Post - evolution 10gx issues
Old 05-14-2013 | 08:00 PM
opjose's Avatar
opjose
Default RE: evolution 10gx issues
ORIGINAL: speedracerntrixie
In 35 years of R/C flying I have never set up a tank so that the clunk moved to the front of the tank.
While not always or usually done, there are plenty of workable ways of doing this.
I don't bother though as there is something to be said for simplicity.
As you say the engine should handle downlines if it is not overly leaned.
Holding the nose down while the engine is running is a useless test.
Nonsense, his engine is not a usual gas engine setup. It requires tank pressure to function correctly.
A nose down test while on the ground will both help establish if the engine is too lean and also help reveal other potential plumbing issues.
