RE: AMR Trainer 26
Well it's finally done. I had some issues with the cg....Way tail heavy. I moved the esc to the outside of the firewall, the batteries are as far forward as possible and I moved the motor out another 1/2". I also had to install bigger (heavier) wheels. AUW came in at 19.5 lbs.......much more than the advertised 13lbs. I ran up the motor today and it produced 1950 watts/50amps, with a Zinger Pro 20x 8, on a 10s 5000mah setup. If I catch a deal on a couple of 6s batteries I'm going to try that. Next step is the maiden, hopefully Friday and for sure over the weekend. Now I have to figure out the trainer function in my 8fg super.lumpy
