ORIGINAL: t-max97
ORIGINAL: supertib
ORIGINAL: Rusty22
Thanks ill look into it! Someone else suggested an O.S. xz-b speed spec2? Do you or anyone else have an idea about these two motors? The HP rating are pretty close to the same but the os is almost $300 more than the B5..
I wouldn't be taking engine advice from guys if they have no first hand experience with the engines being suggested....it is very important to be sure the product being recommended has actually been successfully used by the person recommending it.........Also over time product lines make running changes, some good, some not so good............ Many products may seem very good in theory and end up not working nearly as well as expected........
Are you referring to me or the guy that recommended that engine? How do you know either of us don't have experience with that engine?
well have you used a Werks B5 or B6. ? do you have experience with race .21's ? enough experience to be recommending one over another one to somebody ? do you even own or know how to use a starterbox ?
