RCU Forums - View Single Post - Help Starting .40 SuperStar
Old 09-21-2003 | 12:24 PM
bri69
Default RE: Help Starting .40 SuperStar
Okay, I have a few stupid questions and I know alot of you are going to say "this guy is real dumb" but everybody didn't start with all the knowedge of flying. First question is: When I turn the plane, do I use the Airleons or the Rudder or both? Okay, question 2, when turning, should I apply some elevator? Okay, know for another, how do you check th balance of your plane from side to side? and should I use a ruler to make sure the wing is in the exact center? I know how to check balance from front to back and the superstar is right on the money. Now for the last question for now, I have a field that is 4 soccer fields, so it is about 250 yds long and about 150 yds wide, is this enough space to fly the superstar? Thanks for all the help, this is somthing Ive wanted to do for so many years but just didn't take the plunge untill about a month ago, I purchased a real cheap electric off ebay and I was hooked.
Brian
