ORIGINAL: SJN
Just bought my second Enya 4 stroke
a 60-4C model S7001
The seller advertised it as brand new.
But unfortunatly, it has been started loooooong time ago, and run once or twice maybe judging from te exhaust and parts, then just left there without afterrun oil or anything [:@]
But it is still in great shape, and it will be running well soon after a check and cleanup.
I bought a 46-4C some time back and I knew it was used. I wound-up installing Frank Bowman piston rings and replaced all the bearings (four) and it's fine now. Your bearings may be fine but inspect them for corrosion. If you see ANY rust on any of them I would replace them all. I have a good source for you for the ring and everything PM me if you like at
[email protected]. You bought a nice engine and it's worth a-little TLC.
Cheers,
Bill
