RCU Forums - View Single Post - Something Extra Throws
Old 05-18-2013 | 07:01 AM
Live Wire's Avatar
Live Wire
Default RE: Something Extra Throws
It will fly great on low rates, You will not get the snap roll or stall tendency that you have on high rate. You can switch after you get it in the air and after you get used to the plane you can take off with high rate. Just make sure every thing checks out, CG an lateral balance and all controls are level and in the right direction[:@]
Larry K
